New DJI account
Hello from the Crossroads of America Sojourn1.
Nice to meet you. 🤝
DJI's servers may be down and try again later.
Just a guess, make sure you have an internet connection and have allowed permission for your phone to do stuff.
Other members may have more information, so hang tight and hopefully you'll be flying soon.
Welcome to the Forum. :cool:
How do I resolve this, drone is an Air 2.
Worse case here is the DJI Link to Bind and Unbind a DJI Drone… You will have to move through a few screens to get to the area you want…
Technical Support: Monday - Sunday 06:00AM - 6:00PM (PST/PDT)
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Fly On and Fly Safe…
@Sojourn1,
The members here will help you out.
Is this your first DJI product?
Is this unit brand new?
I almost forgot. :rolleyes:
Welcome to the Forum. 👌
Rod ..
reddflash
