new drone shutdown
thomasoes
UK
Hi all.Hope someone can answer this.I was setting up my new mini 3pro and it would shut down every now and then and said on screen drone was to hot which it was.Is this normal as I never had this problem with my mini 2.The batteries are so light they feel emty
Merry Christmass to all our members 🎅
There is no cooling fan on the mini 3 Pro , I use neck fans when setting up or updating, cheers Len
If you are fiddling with settings and the drone is not flying it is a good idea to direct the output of a fan at the drone, as suggested above.
This has been the case with all the minis, and same with the other DJI aircraft without a fan.
Hi,and thanks for all replies.I was aware the minis dont have onboard fans but was being a bit cautious as the mini 2 never had this and never really got very hot,but I am going to follow the suggestions and will use a fan if doing updates and transfering photos.I am looking foward to using this drone .Once again thanks 🎅
I have updated my mini 3 and left it on whilst trying t get assistant 2 to work. It never seems to get that hot. When flying I aim to get it going straightaway to make best use of the battery. Even with the plus battery.
@thomasoes the overheating issue with the Mini 3 pro, is more pronounced than earlier versions, because there is a lot more going on internally, and all those components produce more heat ,the fact that it turns off is to protect ,those components
This has been a very annoying issue for many,, Me for one. lol
Keys that will help:
Update on a cooling vent.
Get in the Air as quick as you can .
Dont hover to long in the same spot.
and wish you get an Air 2S for Xmas
Phantomrain.org
Gear to fly in the Rain.
I use a fan I took from a PC and point it at the frount of the drone.
Thought it would be better blowing air in the drone 🤷‍♂️
Reactions: careless
ironwingstudios
