New guy here from SE Texas
GalvestonWader
Texas
Hello everyone. I'm a new member from south of Houston area. I'm also fairly new to drones. I learned to fly last year on a Phantom 4 and my buddy's Mavic 3T. Well I recently bought a Mavic 3T for myself. I've been reading stuff online and that's what lead me to this site. Lots of good info here. I look forward to learning as much as I can. Please bear with me if I ask some dumb questions. I'm absolutely NOT the techy type, so I've got plenty of them.
asking so called dumb questions, is how you learn ,and this forum is a great place to learn ,
you can also use the search function, to see if your question has already been, asked and hopefully answered
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
I believe the 3T falls under the Enterprise Series… Below is the link to all of the downloads offered by DJI for the Mavic 3 Enterprise, including the User Manual.
Fly On and Fly Safe…
Welcome "south of Houston area"! Galveston? Lots of good flying there.
I live in Houston, but spend most of my time at our ranch in Brenham. Beautiful wildflower country. I'll post an invite when the bluebonnets bloom, for all the forum members. Some great flying in this area. Independence, just north of Brenham.
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you may have. As Old Man Mavic said, search the forum, use keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response. Fly safe and stay safe!
Hello from the Angleton area!
Thank yall !
Im in Friendswood
Welcome!
Welcome to the forum! :)
A few useful things to get you started:
  • The current DJI drone manual can be downloaded here (it doesn't come in the box).
  • This video covers all the basics of the Mavic 3.
  • Your drone batteries will last longer if you use and maintain them like this.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
kaidoestech
