new here!
Hello from the Crossroads of America Error.
Welcome to the Forum. 😎
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Welcome to the forum! :)
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Living in Volga, be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all.
Drone Flight Application Strategy Digest, continually updated!
The following YouTube Video by Jeven Dovey is well worth watching and you might even subscribe to his channel…
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro Zoom. You will also find the 69-page User's Manual, in case your Drone did not come with one.
Happy and Safe Droning…
Greetings from Birmingham Alabama, welcome to the forum!
smittysflying
