New Matrice 4 Series
AlexisFraNorge
Norway
So the Matrice 4 series just came out. It seems very similar to the Mavic series in all but the name, so I hope it's OK to post about it here.
Here's a comparison based on the official specs between the Mavic 3 Pro, the Mavic 3 Enterprise (with RTK attachment) and the Matrice 4 Enterprise (M4E).
Mavic 3 ProMavic 3E RTKMatrice 4E
Price (Basic Combo)€2,169.00€4,318.00€4,562.00
SPECS
Max Takeoff Weight958g1050g1420g
Folded Size (L×W×H)221×96.3×90.3 mm221×96.3×90.3 mm261x114x138 mm
Advertised flight time43min45min49min
Real world flight time31min33min?
Max Ascent Speed8 m/s8 m/s10 m/s
Max Descent Speed6 m/s6 m/s8 m/s
Max Speed (Sport mode)68.4kph (42.5mph)68.4kph (42.5mph)68.4kph (42.5mph)
Max Speed (Normal mode)54kph (33.5mph)54kph (33.5mph)?
Gimbal Tilt-90° - 35º-90° - 35º-90° - 35º
Temperature Range-10°C to 40°C-10°C to 40°C-10°C to 40°C
Wind Resistance43.2kph (26.8mph)43.2kph (26.8mph)43.2kph (26.8mph)
Max Flight Ceiling6000m6000m6000m
IP RatingNoNoNo
Class (EU)C2C2C2
CAMERA
Main Sensor sizeMicro 4/3Micro 4/3Micro 4/3
Main SensorSony IMX272AQKSony IMX272AQK?
Main Pixel Size3.3 µm3.3 µm?
Main Sensor area (mm²)221.7mm²221.7mm²?
Main Lens24mm24mm24mm
ShutterHasselblad Camera: 1/8000-8 s
Medium Tele Camera: 1/8000-2 s
Electronic Shutter: 1/8000-8 s
Mechanical Shutter: 1/2000-8 s
Electronic Shutter: 1/8000-2 s
Mechanical Shutter: 1/2000-2 s
Medium Tele: 1/8000-2 s
Tele: 1/8000-2 s
Aperturef/2.8–f/11f/2.8–f/11f/2.8–f/11
ISO100-6400 (Still | Video Normal)
100-1600 (Video D-Log M | HLG)
800-12800 (Night)[/b]
100-6400?
Effective Megapixels20MP20MP20MP
Max Video Resolution5.1K/50fps (17:9)4K/30fps (16:9)4k/30fps (16:9)
10-Bit VideoD-Log M, D-Log, HLG-Standard, D-Log M, D-Log, HLG
Max Video Bitrate200 Mbps130 Mbps60 Mbps
Multiple CamerasYes (3x & 7x)Yes (7x)Yes (3x & 7x)
ZoomYes (7x Optical/28x Digital)Yes (7x Optical/28x Digital)Yes (7x Optical/112x Hybrid)
FEATURES
Development SDKNoYesYes
RangefinderNoNoYes
Internal storageYes (8GB)Yes (64GB)No
Obstacle SensorsOmnidirectionalOmnidirectionalOmnidirectional
Global Navigation Satellite SystemGPS + Galileo + BeiDouGPS + Galileo + BeiDouGPS + GLONASS (RTK-only) + BeiDou + Galileo
OcuSync Version #OcuSync 3+OcuSync 3EOcusync 4E
Transmission Range15km FCC/8km CE15km FCC/8km CE25km FCC/12km CE
Live View Quality1080p@60fps1080p@60fps1080p@30fps
Compatible Controller(s)RC-N1, DJI RC, DJI RC ProDJI RC ProDJI RC Plus 2 Enterprise
Here are my preliminary observations:
The M3E RTK and M4E are similarly priced. The M4E has about 9% more flight time according to official specs, and is 35% heavier than the M3E and 48% heavier than the M3P. The drone should remain in the same C2 category as the heavier drones in the M3 series. The internal storage is gone.
The camera(s) and flight characteristics seem largely unchanged, except for slightly faster max ascent/descent/forward speeds. DJI claims "The Matrice 4 series cameras have larger apertures" which doesn't seem to reflect in the specs - what do they mean by that?
The M4E boasts a 112x "hybrid" zoom, what does that mean? DJI also hints at better low-light and night-time capabilities.
The shutter speed seem to be limited to a maximum of 2 second exposure for the main camera, as opposed to 8 seconds for the M3 series.
The maximum video birate has lowered significantly, but I wouldn'd read too much into that.
The new 5-directional oblique and 3-directional ortho capture system seems to imply that you can map a larger area using constantly varying gimbal angles, thereby reducing the necessary flight overlap or flight repetitions?
If I am reading this correctly, I assume this will only work using 0.5s JPG shooting intervals and flight speeds that ensure your forward overlap is maintained at (5 + 1) * 0.5 seconds for oblique or (3 + 1) * 0.5 seconds for ortho between shots. I'm not sure how that would impact the side overlap, especially considering that the pictures would be staggered in the axis of flight direction.
There is also a "Smart 3D Capture" feature that I couldn't find any additional information about.
The M4E offers a rangefinder. Is it used for navigation only? Are we able to access that data on the SD card?
OcuSync 4E raises the claimed transimission range by 10km for FCC and 4km to CE, at the cost of going from 60fps live view to 30fps.
DJI seems to be betting on its accessories and AI, catering to business and public service uses. Some AI detection features seem to have been added, but the extent isn't clear. They also seem to hint at the fact that the detection model can be trained to detect other features? I assume only DJI would be able to update the model, so that would have to be a partnership.
Is this the drone we saw in the alleged Mavic 4 leaks?
Credit: the table is adapted from Gabe Shakour's work
Thanks for sharing!
Reactions: sarahb
I just ordered one (I hope, with the USA cutoms nonsense happening.)
I hope I can help with your questions.
One of the Matrice 4T cameras listed in the specs now has Aperture: f/1.7
DJI calls cameras with both optical and digital zoom hybrid. 112X is a huge jump over the Mavic 3, Mavic 3E and Matrie 3D/T with the latter 2 having x56 hybrid zoom.
Some DJI models had low light modes which did manual settings to get better low light images. On these 2 new drones I know that the thermal model will include a IR illuminator. I am still trying to fully understnad this myself. Someone else may jump in to explain this.
If I am reading this correctly, I assume this will only work using 0.5s JPG shooting intervals and flight speeds that ensure your forward overlap is maintained at (5 + 1) * 0.5 seconds for oblique or (3 + 1) * 0.5 seconds for ortho between shots. I'm not sure how that would impact the horizontal overlap, especially considering that the pictures would be staggered in the axis of flight direction.
This is similar to the same function on the P1 payload, Mavic 3 Enterprise series and Matrice 3D, especially when using Smart Oblique. From using this on a Mavic 3E it seems like the flight plan makes you have less side overlap since the camera will take images from the front and then look backwards immediately. This can make it so that a single flight line captures images from two directions of your point of interest.
The rangefinder is for pinpointing a target which will give you the distance from the drone and the altitude of the pinpoint. Further this pinpoint can be used to orbit around and will show up on your controller FPV, Flight Hub 2 and your map on the controller.
The AI out of the box identifies People, Vehicles and Boats (Max 100 I think), and shows this on your live FPV view. I do not know if you can further train this in Pilot 2, but I am sure that developers can. There is a decent active community here: DJI SDK Forum
Which leaks? The Mavic 4 Pro will be totally different with a round camera/gimbal and different air frame. This was the second bit of leaks that were going around. This replaces the Mavic Enterprise series of drones.
Currently
Matrice 4 Series
Matrice 3D Series
Matrice 30 Series
Matrice 350 - The leaker posted a snip from the FCC on a DJI Matrice 400.
I assume that the Matrice 4D (Dock) series will recieve the upgraded abilties since the 3D (dock) series chared the same payloads as the Mavic 3 Enterprise series
I also assume that the Matrice 40 Series will be upgraded to include the IR Night vision and 12080 thermal resoluton from the H30 payload.
  • Angry
Reactions: jaymc
DJI does have videos posted on the Matrice 4 Series page.
Also Billy Kyle has a test flight of one and shows some of its features on Youtube.
The User Manual and Maintenance manual are both on the main page under Downloads.
Reactions: russellg
When is DJI going to finally put a real good camera sensor in their drones? Something like the ASP-C Fujifilm sensor from the current XT-5. As a serious photographer that's all I want. A real camera.
Many thanks, download and printed manual and put it in a 3 ring binder along with a copy of my part 107, like a boy scout, always prepared.
Reactions: jaja6009
There are clearly two similar, but distinct drones series, Mavic 4 Pro and Matrice 4.
And in my opinion it would be better to correct this:
"video birate"
"the claimed transimission range"
This is going to make the decision hard.
Many of us are waiting for that option. I'm afraid professional photographers are just too small a market compared to videographers and hobbyists who are happy with cheap cameras and lenses. I'm holding my breath for the Mavic 4, hoping it has a better camera and lens. In a few weeks, we will know. Sony had a good option, but instead of trying to fix its issues, they just gave up, and it's been discontinued. Even the $20K Inspire 3 isn't geared toward still photographers. Fingers crossed, the new M4 will be a step forward for us.
Reactions: JeffreyS
Does anyone know if the camera on the matrice 4dt is the same as the camera on the matrice 4t? They look exactly the same cosmetically
Got a reply from a dji rep in a roundabout sort of way. The cameras are the same I think (the way I read it). Unless he meant the drone and the camera are ip55 rated. I read it as the ip55 rated drone has the same camera as the 4t. For me that makes the main factors between the two for standalone use without the dock would be the folding arms of the 4t (wider leg span with legs on the arms, smaller transport size and a camera that should handle getting wet if its the same as 4td camera), vs 4td with ip55 drone body, legs on the body (smaller leg span but higher propellers, plus extra $800 aud). The 4td is cool, but the fact it lands on the drone body every time kind of concerns me a bit for in the long term..
artyboy
