New Mavic 3 owner East London
Welcome to the forum! :)
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Hi all,
New pilot here, any other pilots in east London or Essex?
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Hi guys!
I’ll be visiting Europe in September this year and will be going to London (can’t wait)
Any tips where some good spots are for a mavic 3 used ? I’m in New Zealand so the rules are abit different here but I have just recently signed up to the CAA for the UK to get I.Ds etc
Would love to get some city shots 👌
Thanks in advance:)
Mike
New pilot here,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
As a new Pilot, here is some Good Old Fashion Advice…
Let us know what you are flying and we might be able to hook you up with some great links…
Happy, Safe and Legal Droning…
InspectorTom
