New Mavic Mini Se Owner here
AllysonOfficial
Dallas, TX, USA
Hello! My name is Allyson from DFW area in Texas, new to the DJI family and the mavic series. Owned a 3dr in 2019 but sold it due to downsizing of all my toys. Getting back into the activity and the admiration for the hobby and the photography. Just bought a brand new mavic mini se and added the nd filters and some other accessories, and am absolutely loving this drone.
Greetings from Birmingham Alabama, welcome to the forum!
Hey Allyson,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
With your photography and if you want to sell your work, you will need a Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: AllysonOfficial
Welcome to the forum! :)
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum, welcome as a fellow photographer
Hey Allyson,
Thank you so much for this! It was so so helpful and amazing. After reading all of this and then going thru the resources I am happy to say that I have my Part 107 certification and my TRUST certification which I attained about 2 weeks ago. I also registered with the FAA just to be on the safe side and then did some informational readings too just to gain knowledge on my local and regional laws in light of being out of the "game" for 3 years. :)
So appreciative to this community!
-Ally
bmo4
