ich bought a Mavic Mini 2 a month ago. Right now I'm learning how to fly the Mavic Mini 2 more accurately. So far everything is going well and the shots are excellent.
Welcomeich bought a Mavic Mini 2 a month ago. Right now I'm learning how to fly the Mavic Mini 2 more accurately. So far everything is going well and the shots are excellent.
I believe he has already stated that he has been flying it and taking photos with it, so he's much further along than you may think, having already gone through most of what helpful hints you have posted here.Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
Since you live in Switzerland, there are specific laws and rules for you to follow, please check to ensure these are current.
Drone Laws in Switzerland [Updated September 20, 2024]
According to FOCA, drones are allowed in Switzerland, subject to FOCA and EASA regulations. Read on for details.drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
DJI Mini 2 - Download Center - DJI
Learn and download DJI Mini 2 related apps, software, and manuals at the DJI Download Centerwww.dji.com
Happy Droning…
