New Member from Santa Cruz Mts.
andreinert
Santa Cruz, California
Hello All,
New member from Santa Cruz California. Pretty much a noob (definitely not a pilot yet) with drones, just got my Mini 3 about two weeks ago, Xmas present to myself. Used to co-pilot a Cessna 206 with my brother when I was living in Alaska but, the private pilot thing just became way too expensive. Looking forward to getting out and flying a bit more and will most likely be doing FAA Part 107 through the Pilot Institute.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
I am a proud Graduate of the Pilot Insatiate, so I recommend this if you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3, including the User Manual.
Fly On and Fly Safe…
Hello from the Crossroads of America andreinert.
Welcome to the Forum. :cool:
Welcome to the forum! :)
Hello from Vero Beach, Florida. Welcome to the forum.
Hello All,
Welcome to the forum. Since you are from Santa Cruz, you might be interested in two videos I shot in your area when we visited my grandson at UC Santa Cruz.
Dale
Miami
paul44509
