mavicpilots.com
Tell us something about yourself, are yo new to drones or an old hand, what are you flying?
Since you live in Philippines , there are specific laws and rules for you to follow, please check to ensure these are current.
caap.gov.ph
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
