New Pilot from Amarillo
Bought my Air 3 a month or so ago. My first drone.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome to the forum! :)
Wow. Thank you!
I am TRUSTed. I also have my Registration number on my right front boom.
I have blacked out my flashing LEDs (duct tape FTW). I instead run three nav lights (red, green, and white), and two strobes. I prefer to night fly as I can see the strobes and nav lights 3+ miles out (if I want to go out that far). The 1/2 mile line of sight during the daylight is not as fun to me.
Thank you for all the good info!!!
Reactions: LoudThunder
My two favorite BBQ joints are in your town. Tyler’s & Spicy Mike’s. My wife and I were the first customers in the door at Tyler’s new location. Our picture is on his website in the gallery. Welcome to the forum from NW Montana
somatic
