New Pilot North Texas
Welcome to the forum! :)
Greetings from Birmingham Alabama USA, welcome to the forum!
New Pilot here from North Texas. Starting out my journey with a DJI Mini SE. Only been flying for 2 days, just got my drone up to 265ft today above my house, little scary, but first day. Anyways, just joining to get more knowledge, thank you.
Welcome from the Sunshine Coast in Queensland, Australia.
Many of us would advise keeping your drone low and slow until you feel confident in you and your drone’s abilities. Although very easy to fly it is that ease that catches new fliers out when something unexpected happens and panic sets in.
Now, first off, I am pretty sure you do not know how to REALLY fly your drone, do not get adventurious and push your drone to heights greater than your abilities… Read the following, go onto YouTube and watch Drone videos on your SE and learn to set it up so if it has to Return to Home, it does not fly into a tree or building… We want you to be a happy and safe Drone Pilot!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Happy Droning…
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello from Minnesota and welcome to the Forum....Congratulations on your new Mini SE....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all the drone hobbyist well.
Welcome to the forum from your Texas neighbor in the Houston area. I too rember my first couple of flights with my Spark and that nervous feeling in my gut. But got more comfortable with just a few more and been hooked since!
kaidoestech
