new to community
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. In OC, you can go to the beaches, Manhattan, Newport, etc. There's a small mountain called Top of the World in Aliso Viejo area. That'a fantastic place to see the city and ocean. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
new at this???
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Not sure if you are a new pilot or just new to California, so I'll take a guess… As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
New from Indiana. I’ve been flying little cheap drones for awhile and decided to upgrade to the Mavic 3. I’ve already had the drone taken down by a bird of prey and spent an hour and a half searching the cornfield to find it!!! Good times.
Cheap drones are easy to crash. DJI drones are easy to fly. :)
Hello from a fellow Hoosier in the Crossroads of America sndyrige.
You've tapped into a post a little over two months old.
Better late than never. 👍
Introduce yourself to the Forum with a fresh page if you'd like.
I'll say hi to 'ya again if you do. 🙂
I haven't' lost an aircraft yet to the farmland.
I've had close encounters with the "other" aircraft in the sky during the nesting seasons.
Big fan of prop guards.
Welcome to the Forum. :cool:
Rambezito
