I’m new to the drone scene and I have a Dji
Air 2, a
Dji Mini 2 which I just crashed yesterday and the Tello. I
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Washington, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Even if you have flown Drones before, here is some Good Old Fashion Advice, they might help prevent you from crashing the
Air 2 also…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Learn and download
DJI Mini 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Learn and download
Mavic Air 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
