Hi
You get my meaning, do not go off at high speed and crash it into a tree, house, pole, etc…
But Have Fun!
Thanks TD i took it easy and so far have managed to keep it in the air i am flying in places where there is nothing to crash into apart from the ground while i get used to the controls and am loving the new hobby.
Reactions: LoudThunder
I think you are pretty safe with not crashing into the ground, but it can happen if you are flying on a field that is not level… For instance, the field slopes up a bit from you and you lift off to about 5' and then just fly away from you… the drone will keep itself level with the altitude you flew away from and if the ground rises, the drone may not respond the ground slowly rising and you would "run aground…"
Have fun and do not fly like a "crop duster" as in close to the ground… L 😄 L . . .
aventux
