New User...help please!!
jobie213
UK
I've just acquired a Mavic Pro and flown it for the first time today using the standard controller
But....
I can't find a usable phone app for Android.
I get a message saying "play store no longer has it" or something like that.
I've tried the DJI website but can't find anything there either.
Some of you must be flying using Android
Help please!!
Use the link that Yorkshire_Pub listed above.
Welcome to the forum! :)
Thanks folks. First problem overcome!!
Now here's a new one.
I bought the drone about a year ago second hand
Trying to pair my phone I get the message
"Mavic is connected to another device" and then just turns me away.
It seems like I need access to the previous owners phone...or at least his log in details.
I bought it from Facebook marketplace and have no chance of finding the seller.
Is there another way?
Thanks for your help...
Reactions: RodPad
You'll either need to contact the original owner and ask them to remove the drone from their DJI account or contact DJI support for help. The first is the easiest route.
Reactions: RodPad
Thanks folks.
Can't find the original owner....it was around 18 months ago.
So I'll try to contact DJI tomorrow.
This forum is amazing for speedy responses!!
Thanks everyone
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Fly On and Fly Safe…
@jobie213 firstly welcome to the forum
i am a little bit confused because in your OP,you say you have just aquired the drone and flown it for the first time today
then in your post #7 you say you bought the drone about a year ago ?
Nothing to be confused about.
I bought it around 18 months ago....but gave it attention and flew it for the first time yesterday, 14th January.
That's when I tried to download the app and forum members were very helpful...thanks.
My new issue is that the drone still seems to be registered to the previous owner and its so long since I bought it (on Facebook marketplace) thar I've list touch with the seller and can't ask him to disconnect from it.
  • Wow
Reactions: LoudThunder
Did you try switching the contol mode as mentioned in post 9.
I am under the impression that "register"ing a drone to an owner was introduced when FLYaway insurance became available, if I am correct then it is not applicable to the Mavic Pro.
Perhaps you could post a screen capture of the warning message etc..
  • Wow
On the drone change the switch setting to controller.
Incidentally the contol app is Go4.
I guess that the "DJI Drone" is something you downloaded from the playstore, if so it's probably best to delete it.
  • Wow
My guess is the drone is currently set up to use the phone itself as the contoller, as per
at 22sec of that video you see the guy expose the switch and move it from RC to WIFI, I suspect your switch is already on wifi and you need ro move it to RC.
hesitantextraneous
