Newbie from Rochester, NY
Hello from the Crossroads of America Lummers.
It looks like you may be in a restricted area.
You can download this app and may get authorization to fly at a restricted altitude in the area.
DJI geo zone may have to be unlocked as well.
I don't know how to do it but I think it's easy.
.Good luck and welcome to the Forum. :cool:
Welcome to the forum from Northwest New Jersey. There are apps that you can download to show restricted zones. I personally use Aloft Air Control on my iPhone. LANNC is incorporated into the app so you apply for auhtorization i you meet the FAA requirements.
Hi from Rochester NY. On 6/15 my attempt to demo my DJI mini 4 failed. Restricted zone? Need some tips. Greetings.
Hi Lummers! I'm in Henrietta just a few miles from you. Looks like you are over at RIT. I flew an approved mission there for a photo shoot and it was very tricky as you are so close to the ROC airport departure/approach path. In many spots you are limited to 50 FT AGL. There is also a DJI imposed Geo Zone that you will need to apply for with DJI and wait for approval so you can unlock your drone and controller. Go to DJI and search for Geo Zone unlocking.
Also, beware of any restrictions on RIT campus by RIT Campus Security. There are some buildings with "special projects" that take their security VERY seriously.
Other's have offered you lots of help, now that is up to you… But for you to fly legally, keep reading…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
marcusjohn3684
