Just to say Hello to all! I’m a drone newbie currently using the
mini 4 pro for cinematography
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Find out what you need to know and do when you fly drones or model aircraft in the UK
register-drones.caa.co.uk
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 4 Pro, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 4 Pro
www.dji.com
Fly On and Fly Safe…
