Newbie Here
dondford
Alabama
New member here, total newbie with drones. Retired with plenty of time on my hands and always thought drones were neat, have several ideas on how to use a drone for fishing and hunting. Ordered a "beginner" drone and it should be here tomorrow. My idea is to learn the basis with this drone and if all goes well (and I'm not completely overwhelmed) I will move up to a better drone.
Regards,
Don
Regards,
Don
Welcome to the forum.
Be prepared for a surge of well wishers, welcomers and greeters!
Expect some encouragement in getting your T.R.U.S.T. certificate
and other useful tips and suggestions as you begin your new journey.
Your life will never be the same!
Hello from the Crossroads of America dondford.
Nice to meet you Don. 🤝
If you haven't done it yet, you need to take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
Depending on what you are flying, it may need to be registered with the FAA.
Here's an app that will help you check your airspace before flights and may be able to get permission to fly if you fly near an airport.
Good luck, have fun, and welcome to the Forum. :cool:
Welcome from Bakersfield.
Keep reading the Advice and posts on this forum and you will go Far
As for "beginner" drone as far as that goes- For Camera drones they all pretty much fly the same in the non-sport modes. SO once you get the hang of your "beginner" Drone you will be ready for the larger one. As long as you leave the sport mode alone until you are familier with how the drone flys and brakes- you will be fine.
As a New Drone Pilot, there are a couple of Legal Things you may need to do… @MA2 317 has already given you the heads-up and the links. Please use them, nothing is so intimidating as having a neighbor call the police and they ask you for your papers (TRUST Certificate and Registration if required…) and you replying, "My What?"
Since you live in Alabama, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome to the forum! :)
All these post, nobody asked you what you ordered?
I'm one of the few goofy guys here. :rolleyes: :)
BTW!
WELCOME 2 da FORUM! 👌
Rod ..
Thanks for all the Welcome post and great advice. RodPad, my Attop Pack 18 arrived this morning (don't judge, hoping it will make a OK learning drone...) Knee deep in reading manuals, charging batteries, etc. It may be fairy steep learning curve. Wish me luck. and I apologize in advance for the dumb questions I may be asking....
As they say, the only dumb question is the one you don't ask... Remember, YouTube is your friend, reading the manuals is good, but sometimes seeing it makes more sense...
Thanks for replying to me, so much changed since I bought P2V+ in 2015, no it wasn't $1400 :rolleyes:
I guess you don't need any parts from this one.
I will look your model later!! Thumbswayup👌
Rod ..
youyu
