Hello, brand new drone pilot here,
mavicpilots.com
I grew up in Upstate, Warren County, on the Schroon River, outside Pottersville. You could say the head waters of the Hudson River. That some beautiful county to fly in, the Hudson Valley, hope you send lots of photos for us to enjoy…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Tell us what you are flying…
Fly On and Fly Safe…
