I'm still deciding whether I should get a
Mini 2,
mini 3 pro or an
Air 2.
mavicpilots.com
I own and fly the
Mini 2 and I've flown the
Mini 3 and the Phantom
P4. I have only good things to say about the
mini 2. You have received so many complete, full, and informative responses so far, there is nothing I can add, but I will link you up with all the User manuals for the Drones you are considering. Links at the End…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my
Mini 2 under Part 107.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the Mini, the
Mini 2, the Mini3, the
Air 2, and for good measure, I've included the
Air 2S, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
At DJI Download Center, Learn aboutMavic Mini
www.dji.com
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Air 2
www.dji.com
Air 2S
www.dji.com
Happy Droning…
