It seems that almost every time I fly outdoors I get the warning (in the title) and "unable to hover." I'm using an iPhone 6S with the controller. Any thoughts on how to get connected to GPS more consistently?
Thanks. I'll remember to set it to "auto" on each power up and give it some time. And so I'm clear - Do both the controller and drone need to be powered up for that long, or just the controller/iPhone?The transmission channel doesn't have anything to do with GPS. I leave mine set to AUTO and haven't had any problems. As far as the GPS goes, make sure you have a clear view of the sky. You may have to give the Mini a few minutes to locate enough satellites. I find that if I'm in the mountains where I only have a partial view of the sky, it can take as long as 5 minutes to locate enough satellites to safely takeoff.
Thank you. I'll now remember to switch it to "auto" every time I power up.You can't fix it, it's a bug in DJI Fly, stupid it defaults to "manual" on start-up
The controller and whether it is set to auto or manual or when it was powered on makes no difference to the drone's GPS.Thanks. I'll remember to set it to "auto" on each power up and give it some time. And so I'm clear - Do both the controller and drone need to be powered up for that long, or just the controller/iPhone?
Are you getting this message out in the open where the drone has a clear view of more than half of the sky?I appreciate the clarification. I'm pretty new to all this. Now that I know it's between the drone and GPS satellites I will be more aware of obstacles that block the drone's skyview. I hope it's not a hardware issue. I'll see how things go this week when I'll be flying it again. Thanks ~
