Hello,
My Mavic AIr crashed. Gimbal cable is torn (plug going to pan motor). Mavic has solid red rear light. It doesn't show up in WiFi, even after setting it to "WiFi only mode (button push and 2 beeps). I can communicate with it in newest DJI Assistant, all sensors are working ok, I can download flight logs etc. Even internal memory card is showing up on my computer. Debug version of DJI Assistant sees it as Mavic Pro "orange30" and it can't set correct airframe. I'm not sure about that but to me it looks like it is not compatible with Mavic Air since newest version is working fine. There is no water damage, no obviously broken components (checked under microscope). The fan is not spinning at all, after 2 minutes heatsink is hot to the touch.
Since there are no schematics for the Mavic Air I need your help. Have you ever seen such damage? Any ideas, help, anything?
Thanks in advance!
Thanks in advance!
