On taking off
Tee
Oakland Ca
I notice when I take off my Mavic Air spins around, is that normal? does this happen to anyone else?
There have been a lot of posts about that. You are not the only one experiencing this. Mine does it too but very rarely. It will yaw to the left about 15 degrees or so.
See these threads
Reactions: Mike Shock
15 degree yaw to a side seems different than spinning around. I recommend calibrating the compass and posting a flight log before attempting more flights.
Is it possible that when you are pushing forward on the left stick to climb, you are also pushing it a bit to the side?
Remember that the same stick controls yaw by pushing it left or right
Wesleydjimavic2pro
