Good tip
Another thing that I learnt is the battery temps are around 10 degrees Celcius hotter than ambient air, so on a recent 37 degree day the battery hit 48 while in flight.. The manual only specifies 40 degree air temp as a limit, but doesn't say what battery temps are OK, I would assume around 50 as per my results..
50 is pretty hot tho, I wouldn't want to do it a lot, I'm going to be flying in the WA bush this winter so hoping for low temps!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
