Open CV/ Decoding video
Furqan Ahmed
Pakistan
Hello Everyone,
Actually, I want to run some machine learning models on the image coming from the drone. Can someone tell me how to get the frame from the drone video... I research some info that I need the video decoder to get the frames, so I checked the VideoStreamDecoder provided on the DJI mobile SDK but it does not have getIframeRawId for Mavic air 2. Therefore, I need some help regarding how to implement the OpenCV method for the drone.
Any kind of help would be appreciated. Thanks in advance!!!
Drone: MA2
Hello Everyone,
Drone: MA2
Easiest way is to dump the fpv-widget to a bmp-map. Saves you a lot of trouble. It's fast to. I can do 100fps even from python.
I've written more info about this on stackoverflow a while ago.
Are you trying to analyse video or still images? If video, most video editors can output a stream of images that make up the video. They will probably be jpegs, or perhaps png. Either should be suitable for your analytic sw.
I think he wants to do it realtime, from the fpv stream.
I answered a similar question here. Dead simple :cool:
Thank you for this. I'll let you know once I try this.
And Yes I want to do it in a real-time environment.
Can you tell me how should I mark the objects that I detected on the mobile screen or just for the example show me how to draw a line on the mobile screen in real-time? Since I have never done the bmp-map work before I don't know how to convert bmp-map data back.
Also, I have to ask you this as well. I have seen videos where people actually use mat format to work on the feed coming from their mobile camera. Since I have to work on the feed coming from drone, can you tell me in which format I can perform the rest of my deep learning algorithms?
All deep learning algorithms I've seen using bmp, usually converted to grey. Which one are you looking at?
Take a look at source of tensorflow-lite demo app. Everything you ask is in there.
Heres an example that points the gimbal to a human object.
The bmp is saved to a file, and the reread. A little slower, but fast enough for my use.
def get_human_position(api: MavicMaxLib.Api) -> Tuple[float, float, float, float]:
api.ui.save_frame_bitmap(filename, 50)
img = cv2.imread(filename,0)
x_size, y_size = int(1920/2), int(1080/2)
img = cv2.resize(img, (x_size, y_size))
boxes, weights = hog.detectMultiScale(img, winStride=(8, 8))
for (x, y, w, h) in boxes:
api.ui.draw_rect(api.drone.drone.drawRectXY(x/x_size, y/y_size, (x + w)/x_size, (y + h)/y_size))
return (x/x_size, y/y_size, (x + w)/x_size, (y + h)/y_size)
return (0.5,0.5,0.5,0.5)
fisterc
