Overheating gimbal issue
ackdrone
Massachusetts
Gimbal overhearing warning came on in less that 1 minute of flight. Landed, checked it out and it happened again immediately. The wind was gusty, could that have had an effect? I have not been out since due to weather so do not know if will repeat the problem. Thanks for any thoughts
could be that there is fine dirt or dust in one or more of the gimbal motors ,this will cause the message to appear also make sure that the gimbal hanger is correctly supported by the anti drop hook and forward plates sometimes it can come out and will cause the gimbal to rub against the drone body as you fly and cause a restriction to its smooth movement
Reactions: Thomas B
Augustars
