PanGazer - a new application for viewing Mavic Panoramas
mfc
Kenilworth, UK
I've been working for a few months now on a new viewer for panoramas I've been taking on my Mavic Pro. It is now available at PanGazer - introduction. Here's a summary of the main features:
  • PanGazer is a free (and advert-free) Windows application for viewing images and panoramas, including 360° spherical and hemispherical panoramas as captured by drones.
  • The PanGazer package includes a 'starter spherical panorama’ of the Bejes village and mountains in Spain, taken with my Mavic Pro; PanGazer lets you look around the full 360°, and also pitch up or down, including straight down.
  • PanGazer detects spherical 360° panoramas automatically and you can pan around them easily, but you can also use it for viewing non-spherical panoramas and other images.
  • When viewing ‘hemispherical’ panoramas (e.g., drone panoramas from the Mavic and similar drones) which typically cover 20° above the horizon and 90° below, PanGazer will automatically set the correct horizon.
  • You can save views to disk, effectively extracting individual photographs from a panorama.
  • Strong image enhancements (brightness, etc.) are available to help you identify features of interest.
  • Multiple views (windows) are supported – you can view different images, or the the same image, from multiple angles and zooms at the same time. For example, you can compare still images with views of a panorama.
  • If an image is geotagged (e.g., from a Mavic) you can select 'view satellite image' to see (using Google Maps) where the image was taken.
  • PanGazer uses a fast multi-threaded implementation of the gnomonic projection which reduces apparent distortion of horizontals and verticals. Interpolation is used to improve the display of zoomed or low-resolution images.
All comments and suggestions for improvements are welcome!
Mike Cowlishaw
Very cool! Thanks for sharing, I'll give it a shot!
Reactions: mfc
Hope you liked it?!
Just put out a new version; this one adds two new features:
  • Image files can now be dragged to any MapGazer window to open them; if more than one, new windows will be opened for them.
  • Coordinates can now be displayed in UTM format.
Mike
I really like this. Thank you!!!
It makes pano's worth doing because they look so much better in your viewer.
Reactions: mfc
Some new features in 1.17:
  • New ‘Set image geography’ dialog allows editing the location, elevation, bearing, and tilt data for images.
  • New ‘Show tilt angles’ overlay optionally shows an ‘angle strip’ on the left of a view (similar to the compass points for bearings).
  • The compass points and tilt angles overlays are shown automatically when the Image Geography dialog is open.
  • New ‘Set horizon’ in pop-up menu allows setting the horizon for images (similar to ‘Set North’).
  • Elevations can now be displayed in metres and feet (or both), and can be edited in either unit.
  • Dragging an image to an open PanGazer window now opens a new window instead of replacing the existing image.
Mike
kholik ibnu
