Phone display chunky during flight
WildDoktor
NorCal
Problem? When maneuvering the drone (Mavic Pro 1), if I look at the drone, the drone is moving very smoothly. But if I look down at the phone screen, the video isn't smooth...it's a little chunky / laggy.
Was unit in a crash? No
What have you tried so far? Force-killing (heh) all apps but dji go 4, changing HD Image Transmission between Regular Mode (11.4Mbps), HD Mode (2.7k, 5.44Mbps), and Smooth Mode (1080p, 19.74Mbps). I also extensively experimented with exp and sensitivity settings.
What device are you using ( iphone , ipad, Samsung , etc)? Samsung Note 5, Android v7.0
What firmware are you running ( aircraft, remote controller)? v1.04.0300
What Go app version are you using? v4.3.37(1006-googlePlay)
Any modification?
(if so what) Super-patcher (howto:super-patcher [dji.retroroms.info])
Did you change anything or install any apps? (if so what) I changed some battery warning settings
Do you have a video or pictures of the problem? (if so post link)
Mr. Jeff
