Planetary Gears
Kelly34
Singapore
Hi,
I need to move a 2 meter long arm (like a tower crane) so that it is parallel to the ground.
To achieve a tolerance of about 100:1, I am thinking of using a NEMA 23 stepper motor/reducer connection system with a 100:1 ratio, connected to the arm via a 3:1 ratio pinion and pulley (as shown in the link below). 2 tenths [(1.8/100/3)/360*(2*3.14*2000)] Hopefully the calculation is correct.
https://www.oyostepper.es/categoria-132-b0-Caja-de-engranajes-planetarios.html
Does anyone have experience with this gearbox? Is the backlash measured on the input or output shaft as specified (≤25)? What is the probability that the resolution at the end of the arm is close to 5?
Thanks
  • Wow
Reactions: Cafguy
You lost me at I need to move. But A.I Scares the you know what out of me at times!! I copy and pasted your post lol.
Check out what it spit out to me!! Does this even help? o_O
bileta123
