I recently purchased the gimbal lock for my Mavic 2 Zoom and wanted to know others' opinions on it. It seems really tight and pushes the gimbal up and back when attached. Is this bad for the gimbal?
@Thunderdrones
@Thunderdrones
I use this one on my M2P. My opinion is no it does not.I recently purchased the gimbal lock for my Mavic 2 Zoom and wanted to know others' opinions on it. It seems really tight and pushes the gimbal up and back when attached. Is this bad for the gimbal?
@Thunderdrones
Here's a video that shows the movement the OP is referring to:
@Thunderdrones
I'm using that lock on my Mavic 2 Pro. It doesn't put pressure on the camera/gimbal and completely encloses it. Love it!It looks like it "nestles" the gimbal instead of stretching it, and Im interested in hearing from anyone who has used one like it.
That's a good plan and they are cheap enough.Think I’m going to go ahead and order this one just so I don’t have to lose sleep over it lol.
I had that one and within a couple of flights the ears that clip in behind the gimbal broke off.I'm using that lock on my Mavic 2 Pro. It doesn't put pressure on the camera/gimbal and completely encloses it. Love it!
While not an issue for me, some people mention the camera is able to move slightly while the lock is attached (which is does). If that bothers anyone, you could stick a piece of foam tape on the bottom of the cover (on the inside) to fill the tiny gap that allows that play.
Mavic 2 Pro Gimbal Lock/Cover
Mavic 2 Zoom Gimbal Lock/Cover
I've seen a few other people mention that too. I'm wondering if it has something to do with the way people use it. I must have removed mine at least a hundred times so far. It's still working okay for me.I had that one and within a couple of flights the ears that clip in behind the gimbal broke off.
Seems like there is only one very simple way to use it. I can’t imagine what I would have done to stress it incorrectly. Maybe there is variability in the manufacturing and some are weaker than others.I've seen a few other people mention that too. I'm wondering if it has something to do with the way people use it. I must have removed mine at least a hundred times so far. It's still working okay for me.
It seems people are somehow stressing the tabs on the front of the lock. They probably aren't just falling off, right?Seems like there is only one very simple way to use it. I can’t imagine what I would have done to stress it incorrectly. Maybe there is variability in the manufacturing and some are weaker than others.
That happened to Me Too! Once or twice. If you buy it off of Amazon and it breaks just return it for free and get another one. It's still better than the alternativeI had that one and within a couple of flights the ears that clip in behind the gimbal broke off.
Mine did, too, and that's when I bought the PolarPro. But I wince when I snap it in place.I had that one and within a couple of flights the ears that clip in behind the gimbal broke off.
