Portuguese drone enthusiast back in action
rjSampaio
Portugal
Hi everyone,
After years without flying a drone i decide to get myself a DJI AIR3 + rc2.
Believe or not, my first drone was quadrotor build at my school around 2002, made purely by "hand" with carbon/kevlar fiber and custom electronics and "home printed" pcb, even the microprocessor was programed by me in assembly, the rotor blades had a diameter of ~50cm, so basically accident waiting to happen.
The controls were sloopy, we only had 3 axis gyroscope the size of a finger back then, and we had to solder a second one vertically to have any sort of stability.
Today, the mini series is almost as tall as my gyro back then, it's freaking amazing.
I'm more of an astronomy enthusiast, but i believe i can double dib our sign off catch phrase "clear skies everyone".
Welcome to the forum @rjSampaio1
Welcome to the forum from the beautiful woods of Maine, USA!
Reactions: LoudThunder
Welcome from……..Porto! Visiting your beautiful country and this City for the first time but, sadly the authorities require me to have too many qualifications to fly here so my Air 2 is “resting up” in it’s cupboard in the U.K.! Sun is out, roof top bar open-all’s well.
Welcome to the forum. We look forward to your participation and your view of the world.
Since you live in Portugal, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
wang
