I think you have good footage, the advantage of 4k is you can do a lot in post production, except for a few soft focus scenes I like your footage.What would be the best settings for the Mavic Pro for shooting Track and Field shots?
I'm using true 4k at 24FPS right now. Seems to be working out alright, was just wondering if there were better settings for this type of shot.
Below is an example of what I've done
You can try Active Track, spotlight sub-mode. If someone else is filming, you can fly your Mav anywhere you want and the subject will remain in the shot.What would be the best settings for the Mavic Pro for shooting Track and Field shots?
Regards,
-d.
I think the 24 fps looks more natural, 30 will look more like a TV or video, are you doing this for training purposes? If so 30 fps will give you five more frames to analyze your stride (the person in the video has a nice stride.) The filters should help quite a bit and will look amazing at 24 or 30.I just received the ND filters to help with that! Hopefully the 16 grade is good enough for Florida sunshine, if the exposure on the sky is still off Ill get my hands on the 32 grade filter.
So do you think 24 FPS is fine or should I switch over to 30 FPS?
I've done active track, the standard track mode stays a bit too far back for my liking. In that video I had profile tracking which works better and stays closer; only issue Ive had is where I've kept my drone to close at the start and it loses track of me. Ill give the spotlight mode a try! I haven't tested that out yet
Regards,
-d.
