Red images with horizontal lines
reynoldseth
illinois
Hello I’m having a really frustrating issue with images being saved are discolored and some have horizontal lines through them. I’ve shot in several different locations and have saved images in jpeg and raw. I can’t seem to find anyone else with the same issue either. Image shows up ok during live view during flight but when an image is captured it is captured with a red or purple saturation. I’ve included examples.
I don't see much in the way of horizontal lines, but I sure see the coloration. If this is a new purchase, I would return it for a new one (no reason for you to bear the burden of repair if new).
If you had this AC for awhile and it was fine before, did you have any crashes or subject the camera to extreme heat?
It looks like a damaged sensor. It could also be a loose multi-pin connector, but I haven't had to fool with those myself on the Mavic (some old phantoms could give weird results if an MPC was loose).
Chris
Reactions: reynoldseth
I think you are on the right track. Those pics remind me of what happens when one of the pins on an (old) RGB cable was either mis- or dis-connected. Definitely not right.
Chris
Thanks man I think I am going to be contacting DJI because I’ve tried just about everything I can do with no luck. It is fairly new maybe a month or 2 old and it was working fine when I bought it. No crashes or extreme heat.
robqwe
