Reverse Point of Interest
kcoleman805
Is there a way to use one of the Mavic "modes" to basically do a shot that is a continuous circle at an adjusted speed but instead of the camera pointing at one object it is pointing out and getting the whole surrounding area? Like if you were on top of a mountain or somewhere in nature, could you set the camera to circle to get the whole scene in the shot without having to manually control it?
Yes, just set your reference point and then your speed, altitude and distance from the reference point.
Use the left stick to yaw the mavic so that the camera is pointed directly away from the central point.
Thanks so much! :)
venoom2001
