Above the tallest building or tree that might be in the way.What about altitude setting for RTH?
As I said, 'where I fly'. YMMV.30 mtrs. = 100 Feet..... I wonder if that is high enough to clear houses and trees in the city?
I say that obviously it needs to be set higher than the tallest thing that may be in the flight path. Remember that the Mavic does not follow the path it took to RTH, it will make a straight line from where it is located to the RTH coordinates. If you flew behind a 100ft tree, then RTH needs to be higher than that. It may be tempting to just set it to max altitude, but the winds can get significantly stronger at altitude and prevent the MP from making progress against the wind. So I set it as a pre-flight step after looking around the area.Whats the best setting for RTH?
I hope your not flying in the city with out clearance, it will give us a black eye but if you are 200 up for me.30 mtrs. = 100 Feet..... I wonder if that is high enough to clear houses and trees in the city?
I disagree. The height should be set to your local surroundings. There are no Oak trees where I fly. In the desert my RTH alt. is 10 mtrs. No point going to heaven if you are coming back to earth anyway..30 mtrs is really the bare minimum since Oak trees can reach 80 feet tall and a few others even taller. I set my RTH at 50 mtrs to be sure. Also, not sure how accurate the altitude sensors are
I keep mine set to 80 metre to 100. I keep it on a high altitude as this is something I always forget to set when I'm flying in different location, better to be safe. London has all sorts of tall buildings.Whats the best setting for RTH?
In a built up area I like 120ft, but it's something you have to consider when you go awayWhats the best setting for RTH?
3.37 feet = 1 meter.Just multiply times 3 to go to feet from meters. That will give you a little extra as it is actually 3.14 I Think. Also if you take odd in a valley and you fly over an area that is higher than takeoff area, you calculate from the launch point. We have tall Carolina Pine Trees that can reall present a problem,so higher is better as if the MAVIC is in the tree that high, no way to retrieve
