sensor advice
Irish-apple
IRELAND
Lads n ladies needing some advice ..
been asked by the company I work for to do a project .. using a phone { which they make } I've been asked to make a small short film with it .. great excellent .. not heres the thing I know the what if and what etc .. the sensors under the mavic can I somehow strap a phone under the mavic and sen d it off recording as they be like WTF how you get those shots on a phone ..
I know the danger before I do so IF I do so etc any advice etc or ideas of what and how to be appreciated in advance
.. ps sorry cant mention the company name but if you knew by my posts what type of device I use you will then know the company itself thanks
so can the sensors be covered safely for a short time .
can I find a way to get a phone on the mavic
can anyone help thanks again
any advice be it criticism /help /ideas I dont care throw them in the comments im IRISH I can take it and give it back twice as good lol
on the mavic you can turn off the "downward vision positioning" in the DJI Go 4 app, then you can strap the phone to the underside.
The trade offs of turning it off are the low altitude hovering accuracy, precision landing and landing check, which should not be a problem
Reactions: Irish-apple
thanks a million pal that easy lol I always land by myself etc and have good control of the mavic so thats excellent cheers buddy not to get some cable ties lol this should be fun
You might want to be careful strapping a phone to the bottom of your Mavic. The heat sink is right there and runs the entire length of the bottom, plus your fan exhaust is towards the front. Blocking the heat sink could cause internal component teperatures to rise, and blocking the fan duct could have the same effect. Also, you might not want a 120° heat sink attached to your phone, it could cause damage to the phone. It might also lock up or get screen burn if subject to that kind of heat.
cheers pal I was thinking of that also about the heat etc I wont be flying long maybe about a 30 second trip each time and let cool down etc but cheers
I guess if you get your footage right after you start the drone, and limit it to less than a minute, you might be okay. The drone usually reaches its hottest after the fan kicks on at around 30 seconds to 1 minute.
Good luck with your project.
Wesleydjimavic2pro
