Separate adjustment settings in standard and sport flight??
hidaven
I just set all my stick parameters for smooth flight, I.e. Expo, braking, yaw endpoint etc. all is fine except that I loose everything once I set to sport flight via switch on RC side. Is there a way to also tune sport flight, or are the settings only good for standard flight? TIA!
I believe the settings tweak will only work on the normal mode...
NO way so far to tweak sports mode, or tripod mode or cinematic mode..
(sigh)
If I'm remembering this right (I swear I saw it on a YT video)... Go into your Expo/breaking... etc. settings, then flip the switch on the remote to Sport mode. The values for sport mode should populate the fields and be editable.
Thats interesting.. gonna try this for cinematic and tripod mode while I am at it...
Actually I just tried it, only lets you separately adjust the EXPO. Unfortunately the other parameters don't have separate adjustments. : ((( Thids cant be a hard fix, hopefully a future FW update will allow this.
Wesleydjimavic2pro
