SHOULD I OR SHOULDN'T I UPDATE FIRMWARE
I'm on 01.04.0100 and have no height limit, sport +, nfz disable, etc available
I have every feature new and old except precision landing which I never use (always fly back manually)
But can't rollback, correct? If some other awesome param mod is found later, and it's only available with, for example, .700 305&306, you won't be able to take advantage of it?
For example, if someone found a way to remove those stupid 5/20m boundaries where it lands where it is vs. always doing RTH the same way, I'll be extremely happy! I love Precision RTH (although I do a mix of RTH/hand catching), but I hate it that when I want it and am within 20m and OA is disabled, it will proceed to landing where it is (which is usually desert scrub or rocks), I have to first fly it outside of 20m, then hit RTH for precise landing on my landing pad.
Reactions: Chirp
I know this buy I temporarily forgot. What's OA? :confused:
its described in the rollback thread
If you are already on 01.04.0100 you can't do it
Else flash 01.03.0700
Then open 01.04.0100 bin file, delete 305 & 306
Flash edited 01.04.0100 bin
Test
Test
Thank you for the input! i guess im out of luck.....already on 01.04.0100 :(
cheers!
Ya know for several years I've always kept firmwares updated on things like ESC's and FC's but
I am honestly not really getting the warm and fuzzies on moving forward on the Updates for the Mavic.
Nothing against DJI or the products and I do understand there always seems to be a bug now and then.
But it seems the reading I have done the last 2 weeks (here as well as other areas) has me a bit hesitant.
I'm sure the issues I am seeing are not as widespread as it might seem but I may sit tight for
a bit longer and see if this mention of problems, dies down some.
stephy_gl
