Show off
inzagi Minero
Ottawa
Trying to flunt rn
Just got these last week
I'm now a mini 4 pro user getting ready for take off
Have not yet really gotten time to take a first flight due to work and I want it to be a special first flight
What's the best app to use I'm tryna start my set up
Reading material.
The Fly app is what’s needed.
If you don’t hear the voice telling you the home point has been recorded, leave it on the ground. Best to do some reading first.
Be safe!
The mini 4 pro is pretty foolproof but any foolproofing can be overcome by the determined fool. ;) First, use an app to determine if the area you intend to fly in is OK to do so. If you pass that test, listen/read any warnings on the screen during initialization, take off and flight. The one failing with the mini is it is easy to lose sight of, being so small. Because of this, I would familiarize yourself with the return to home feature. Having an extra set of eyes can help for those moments when you have to look at the screen. Also, selecting a place without trees will make flying easier for the first flight. Pay attention to the battery level!
It goes without saying that reading and understanding the manual is important. The first flight is exhilarating, even if it's not far or long. Concentrate on learning how to control the aircraft rather than taking picture or video - you'll have plenty of time later for that.
You'll find that it's much easier to fly than you imagine.
It takes about 5 minutes to learn the basics - but a lot of practice and experience to become proficient.
Don't let the simplicity make you get too adventurous too early.
There are many things that can go wrong and you need to understand what they are and how to make sure they don't happen to you.
But for learning, the critical thing is to practise in a large clear open area, well away from trees and buildings.
Flying close to obstacles is by far, the largest killer of Phantoms.
Obstacles are the number one enemy of drones.
Before your fly, have a look at the Pilot Institute's "Deep Dive" video on the Mini 4 Pro. They also have a good basic introduction to drones video, too.
Take your time. Do not rely on the drone's obstacle avoidance feature or use any of the automated flight modes until you've built some hours.
Thanks I think I'll check that
Reactions: LoudThunder
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum. We look forward to your participation and your view of the world.
hesitantextraneous
