Signal Booster Around Buildings
Basheer
DUBAI/UAE
Any product that can enhance signal around corners of buildings? other than the foldable signal booster that is installed on controller, this one extend range. Iam concerned about obstacles that disrupt signal transmission such as buildings (Iam running a construction site so i can install any antenna on buildings)
Thanks
Welcome to the forum.
Autonomous waypoint mission apps like Litchi can get you around your construction project’s corners, with saved, repeatable missions. Not sure what you‘re flying in the UAE, but today Litchi works with MP, MPP, M2Z and M2P.
The laws of physics rule. WiFi does not go around corners. It is straight line los, and competes with all other WiFi signals in the area of the ac and rc. It is not a DJI problem.
This really helpful and I got it for 25 USD download. Thanks buddy
Reactions: pelagic_one
Was thinking if reflectors in different angles from lower elevation around buildings to higher where it can be directed toward controller. However iam using Litchi now and seems to be ok. Thanks
Please, Tell me more of this Litchi App. Id think it still requires LOS for signal reception to the RC? When you speak of around corners what is meant? Id like a program to design search (SAR) patterns, property boundary surveillance/assessment; input A-B-C...Z fly points. MA2 and MM2 at hand.
Litchi doesn’t currently have a waypoint feature for the MA2 or the Mini. If you want that facility, Dronelink and Mavic Maven both currently offer it for those drones. However, they’re not truly autonomous missions because they use the “virtual sticks“ method which requires the remote controller to continuously send control inputs to the drone.
It’s worth pointing out that true autonomous waypoint missions where the drone flies beyond radio range of the controller are illegal in most countries without a special waiver.
alanmeg
