- Joined
- Jul 2, 2019
- Messages
- 69
- Reactions
- 10
Hey folks its my first post just started flying a mavic air.
Wasn t getting much distance and tried a few different things.
For distance i was easily achieving 500m then video started lagging decided to come back home.
I decided to remove my slow sandisk ultra card and started flying without it. Also tried lowering to 1080 30fps. Only once removed i was able to easily get 2000m into the wind.
This test was done in same conditions and same path. With and without sd card.
So either i found a solution or for others to test and try if having similiar issue.
I have purchased an extreme card instead so maybe with the right card there wont be issues, ill need to test again, but very strange coincidence that a slow sd card can limit the distance and lag the video broadcast.
Having said that i was on 5.8ghz on both occasions.
Again im very new to this so if anything i said is completely incorrect please advise. Its simply an observation. Clearly flying with no card at 8gb internal memory is not a solution but thought i would mention it.
Lastly what do you think about 2000m where i have interference everywhere (5.8 ghz) 2.4 was not strong 700 m out so not touching 2.4 in the city.
Firmware updated via the app, never connected to dji assistant 2 yet.
Any thoughts or suggestions?
