slowing down the speed the Mavic turns around
TraP
Any thoughts or suggestions on controlling (slowing down) the speed at which the Mavic turns around (apart from pushing the joystick slowly)? Anything in the settings which we can be set to slow this - just like we can slow down the gimball tilt speed? Thanks!!
Practice (that's not meant to be sarcastic).
There is no substitute for putting in stick time to gain fine control
You could slow down the yaw speed by tweaking the EXP/Gain settings in the "Main Controller Settings" --> "Advanced Settings" section of DJI GO. Doing so will prevent you from turning quickly when needed though.
Reactions: simplyRik
Tripod Mode is crazy slow. It's not something that'll be useful for people on most flights.
Thanks guys. . I guess practice in controlling the sticks is key then.
Listen to @msinger in the post above. Drop the YAW EXPO to 0.2. This make the sticks more sensitive near the centre.
I wish there was a yaw setting similar to the gimbal where you can adjust the rate at which it slows down after panning. Anyone think this might be a potential firmware update?
Reactions: erikgraham
thelelans
