So is the problem with the firmware or the props?
I place my sd card Lightning adapter cable under my Mini while it is being stored in its case. That allows the motors and props to hang in the air because the Mini is lifted about 1/4 inch. No pressure on the rear props or the motors.
Not buying the whole "just replace the props" for the following reasons:
1. If it were a sole prop issue then it would be simulated across all firmware versions since it affects physical properties.
2. it's an imbalance of increased motor speed. (rear speeds up but fronts don't get the same message)
The big issue before the update was fly aways during high winds, so i believe that dji increased the motor speed paramaters to counter this. Unfortunatly it looks like the alterations were imbalanced resulting in increased speed on just one prop instead of all. I'm not saying the props are not an issue but the trying to pin it on as single cause (props) is inaccurate from what i see.
Reactions: Garbage
droidboi
