I’ll start by saying I’ve used the search feature extensively as well as on the DJi forum, but haven’t found any solution and most posts seem to be at least 4-6 months old.
I’ve got my Apline white MP out for a couple good flies so far to stretch its legs, I have about 1hr25 min in flight time on the unit.
•Gimbal vibrates almost consistently when moving, low wind & high wind. Been up 300ft with no wind warnings and as soon as I start to travel in any direction at even 2-3mph it’ll start. Same thing with no breeze at 6ft off the ground, as seen in attached video.
•Gimbal decides to do its own thing for a few seconds, this issue is fairly intermittent, only had it happen about 4-6 times. Video link attached.
•The camera intermittently seems to lock up on the tap to Focus side of it, blurs out and won’t tap to focus or even refocus in manual mode.
•I’m also dropping video feed intermittently about 300 feed out, with the vide screen freezing but all my data staying live, sometimes I can swap from photo to video and it’ll come back sometimes not. This I’ll somewhat attribute to interference.
-Hasn’t been crashed, MP firmware is V.01.04.0300
-DJIGo app firmware is V4.2.14(3118)
-No mods
-No error code
-Gimbal brackets all where they suppose to be
-Ruled out SD card, happened with original & my 64gb card out of my GoPro
-Was thinking wind, but at the time shown in the video I was low & slow and there was barely a breeze
-It was chilly, I’ve read that could be a cause for the vibration, may test is the warehouse a work to see.
I’ve calibrated and re calibrated everything, using supplied SD, reformatted before each flight. I haven’t tried rolling back to the previous firmware versions.
Am I missing something simple, or did I get a bit of a lemon of a gimbal? I still have 10 days that I’m able to return to Apple for replacement/refund.
Also sorry for the winded post, just looking for some insight/input from this great community. So far, beside the issues stated I’m throughly impressed with the Mavic, love the portability, solid flight time, and it has awesome stability in the wind, which is a must where I’m located.
-No mods
-No error code
