Sound like a good idea?...
Josiah S
haiti
So I found this case thing you can put on your bike. I tried it out and found that the controller fits perfectly in the bottom compartment and I can connect the cable up to the phone that fits in the phone slot on the top. So far it all fits perfectly. The thing I am worried about is I cant get to the controller very good in case of emergency. My thought though is I arrange the drone where I want it, pack everything in the case, start active track and start biking. If there is a problem I can cancel active track from the phone and then unpack everything and do what ever needs fixed. Does this sound like a good idea or is it crazy? I don't want to help anything bad happen to my mavic. By the way it is a mavic air 2 and I am not sure how good the active track is on it. Is it reliable? Thanks for your replies. Please tell me if you think you would do it and what you think I could do better.
I have one of those cases or very similar one, on my bike. Be careful in hot sun though, because the exposed phone screen can heat up under that plastic top clear sheet and then you won't be able to see anything on it.
O'Ryan
