Hi
Hope to do the upgrade shortly but concerned that the android device (Nexux 7 2nd edition) I'm using with the Spark will not work with the Mavic ?
When I started with the Spark I had some difficulty with the connection and was advised by a member from the DJI Forum that in order to use my Nexus, I should downgrade the software and "install 4.1.15 or 4.2.12" after doing that, all worked perfectly with 4.1.15. I also received the following information:-
"As all the new versions of the app require more and more powerful device to work properly as more stuff and things are added to the app.
For example for the latest 4.3.1 to work properly on your Android device, the device in question needs to have at least 4gb of ram ( better to have 6 go of ram)"
If that information is right then can I assume that the Nexus won't work and that I'm going to need a different android device ? (any suggestions as to the different device ?)
Thanks
Thanks
