Same here!They will just change the "Tone" of your props Not the Noise. I only know of one other prop besides O.E.M. that won't make your drone vibrate like crazy and those are Master Airscrews. I won't use any others besides those two..
Not really BUT Besides the Airscrews- I think they would make your chances of having to use care refresh more likely.Would using aftermarket propellers void Care Refresh?
Would probably be difficult for DJI to determine what props were being used if and when damage occurred. I would not rule that idea out with the information that may be available to them through the flight data. (past my pay grade)Would using aftermarket propellers void Care Refresh?
I'm sure with the new update with side vision cameras able , that DJI could see the props you are using now .Would probably be difficult for DJI to determine what props were being used if and when damage occurred. I would not rule that idea out with the information that may be available to them through the flight data. (past my pay grade)
I am sure they could always access the obstacle avoidance cameras’ data and visuals, before they ever gave us the ability to get limited visuals from those cameras ourselves.I'm sure with the new update with side vision cameras able , that DJI could see the props you are using now .
Thoughts
I think that the lower pitch does result in a lower perceived volume to the human ear.
I've always bought MAS blades for their colors - helps me easily spot the drone if I happen to land in a tree or the bush.FYI, I did choose the black colour for the MAS rotor blades, as black has the highest resistance to UV damage from the sun.
As well you should. What slight amount of difference in sound and performance(or lack there of)isn’t worth the expense. Your results may vary.tend to discount manufacturer hype
There are sometimes sales on the MAS prop blades which make them lower cost than the O.E.M. prop blades.As well you should. What slight amount of difference in sound and performance(or lack there of)isn’t worth the expense. Your results may vary.
