Strobe lights and photography
I have the ARC XL white on front arm, Red on the rear.
I only encounter problems if I am close to the object. 99% of your photography and videography will not be affected. Enough not to stress about, benefits especially for VLOS weighs out the rare times it will be an issue.
I have been using a top mounted LED strobe for all my night flying, I find that because of the relative cover/shade that the gimbal has, so far I have had no sign of light leaking from the strobe. However you can get light from the strobe bounced back from reflective surfaces
I don't have a Mavic Air 2 but on my old Mavic Air 12 I put the strobe on the bottom because I could see it better. Is there room on the bottom?
One more thing to think about, if there is any atmospheric moisture (i.e. fog/mist) there might be some scatter back to the lens. But you shouldn't be flying in fog or clouds anyway. ;)
My understanding is that the strobe is a FCC required item for flying at night, though useful as a way of tracking your drone this is not its true purpose, so mounting it under the drone would defeat its intention as a notification to other aircraft The PIC should be able to track his drone using the inbuilt LED lights.
I have not mounted any strobes yet on the MA2, but I have mounted them on the Spark and I would advise not to mount them on the bottom near the VPS camera(s).
I had a very short erratic flight when the strobes were affecting the VPS camera on the bottom of the Spark and it had a rough landing because it couldn't "see".
I like that the MA2 has a auxiliary landing light.
Dimension Drone AZ
