2) a useful strobe will put the
Mini 3 over 250g, anything self powered and light enough to not do that <1?g will be useless.
One powered off the drone's battery might be strong enough to be useful but I haven't seen such a strobe.
Being honest, if you lose sight of a small drone because of distance and then lose all sense of where it is, it is difficult to spot a strobe, i.e. you need to know where to look.
That was my findings with
the Strobon cree
STROBON Cree® Standalone .........4g
and
the firehouse Arc V
Firehouse Technology. Arc V. professional LED drone strobe light (white). : Amazon.co.uk: Toys & Games ..........14g
I wouldn't put an arc v on a Mini xyz.
With a
mini 2, my sight limit is around 600m background depending, the strobon might have increased that a bit but if you note the "might" you might deduce that I do not use the strobe on a regular basis, infact I would struggle to remember the last time I used it for anything other than a test.
Incidentally if you do get a strobe be carefully where you are looking when
a) you test it or switch it on, or
b) when you are trying to switch it off or
c) have the drone close with the strobe facing you.
I ......now........put my thumb over the LEDs during switch on/off and do not look at the strobe with the drone in flight i.e. the drone is pointing away from me.
Looking at the strobon was bad enough, the arc v is much worse and left me seeing spots for quite some time.
